Circular Honda Fallo Cardán VFR1200F
Iniciado por Sonic, Diciembre 04, 2015, 11:37:34 AM
Circular de Honda sobre posible fallo del cardán de la VFR1200 en unidades con cierto número de bastidor y con fecha de fabricación entre Feb 2010 y Feb 2015.
http://www.honda.co.jp/recall/151203_3709.html
Recall of the VFR1200F, VFR1200X (notification 12/3/2015)
Recall notification number  3709
Recall start date 04/12/2015
Defect parts (part number) power transmission equipment (propeller shaft)
Standards non-compliance status to the structural finds,
Equipment or performance condition and its causes
Yoke joint propeller shaft there are because the shape of the housing, to maintain pressure and bearing and fasten the bearing through the prevention of inappropriate heat caused by friction during driving and high load bearing internal wear. As a result, you may yoke joint is damaged and keep the vehicle in its entirety, or undrivable and worst case, propeller shaft and interfere with the swing arm, rear wheel to lock.
Replace the products your propeller shaft of the improvement measures. However, York Joint malfunction is confirmed and takes time to supply products that, as an interim measure for the time being, the propeller shaft check out what the new replace the propeller shaft.
Honda
EBL-SC63    VFR1200F
SC63-1000020-SC63-1001061
02/03/2010-09/12/2010     1042
SC63-1100001-SC63-1100326
20/01/2011-17/01/2012    326
SC63-1200011-SC63-1200177
20/02/2012-31/10/2012   167
SC63-1300001-SC63-1300206
06/11/2012-13/07/2015     206
EBL-SC70   VFR1200X
SC70-1000005-SC70-1000115
20/02/2014-02/09/2015     111
(Total 2)   (Dos modelos)
02/03/2010-02/09/2015   (1852 unidades)
Mr. T
no me entero, la mia tiene letras y numeros despues del sc 63
Cita de: Mr. T en Diciembre 04, 2015, 12:45:47 PM
¿Pero tiene una secuencia de siete números seguidos?
Mr. T
Entonces parece que no te toca ¿no?
Aunque sospecho que esto será como el fallo crítico del estator en la VTEC... simplemente Honda Montesa no se subió al carro. El fallo se da en España pero no lo cubre Montesa.
:icon_evil:
jaem
¡Muy buen aporte!
Según entiendo,  la 1200 X, anterior a 2014,  no está afectada,. ¿no?
"No hay lugar en el mundo
donde mi imaginación
no me pueda llevar"
Cita de: jaem en Diciembre 04, 2015, 02:53:24 PM
¡Muy buen aporte!
Léelo otra vez
isislot
Lo he puesto en el traductor de google, y de lo que me dice, no me entero de nada  :bawling:
Resumanmelo por favor, pero como si fuera para un niño pequeño.
Por cierto, donde mirais vosotros esa numeracion. Gracias.
TODA DECISION IMPLICA UN RENUNCIA.
majenjo
Cita de: isislot en Diciembre 04, 2015, 03:33:19 PM
Si lo ha puesto Sonic, es normal q no lo entiendas.
Pero es de agradecer q se moleste en poner estas cosas, es como un gran Padre en este foro.
Enviado desde mi P6000 Pro mediante Tapatalk
jaem
#9
Honda
EBL-SC70   VFR1200X
02/03/2010-02/09/2015   (1852 unidades)<br/>
Pues eso, creo que la 1200 X.(crosstourer) , afectada desde 20_2_2014  al 2_9_2015
no me pueda llevar"
Cita de: jaem en Diciembre 04, 2015, 04:29:38 PM
Honda
EBL-SC70   VFR1200X
Aaah perdona... la X... no vi la equis...
isislot
Pues eso, que sigo sin enterarme si las modelo F, estan afectadas, porque mi numero de bastidor, no se parece en nada, a ninguno de los que pone hay. Un saludo y gracias.
Maka
A alguien del foro ya le rompió, y reclamó a Honda lavándose esta las manos...
Buen argumento para denunciar...
Arri
Montesa Honda tiene en su web un apartado en el que metes tu número de bastidor y te dice, teóricamente, si hay alguna campaña respecto de ese vehículo:
http://www.honda-montesa.es/campanas-tecnicas/index.php
:drink5:
George Bernard Shaw
isislot
Pues después de haber metido el numero del bastidor, y comprovar que no hay nncuna campañana pendiente. No me quedo mas tranquilo, porque eso no garantiza nada, encuanto a algun posible problema, no declarado oficialmente. Un saludo y birras pa to Dios.
Es posible que sea el número motor y no bastidor?
isislot
La pag, especifica que es el numero del bastidor, que es el numero que figura en los papeles de la moto, asique estamos como al principio.
Yo lo leí por primera vez en un foro americano y allí ha dicho uno que es el número de motor, tampoco me cuadra porque todos tendrán el mismo número de motor, si le pasa como a la vtec, además estas cosas suelen ser por número de bastidor... xo lo mencioné x si acaso
bueno yo he escrito a HONDA ESPAÑA y me han dicho esto, copio y pego
HONDA Spain INFO MC <atencionalcliente.motos@honda-eu.com>
13:12 (hace 8 horas)
Estimado Sr. González,
Gracias por contactar con Honda España.
En primer lugar, le comunicamos que Honda, junto con la DGT, envían cartas a todos nuestros clientes con vehículos afectados por campañas técnicas, por lo que si su vehículo está afectado por alguna campaña, Honda le enviará dicha carta a su domicilio.
Tras consultar su número de bastidor, le informo que por el momento su moto no tiene ninguna campaña pendiente.
También puede comprobarlo usted mismo en nuestra página web http://www.honda-montesa.es/campanas-tecnicas/index.php introduciendo el número de bastidor de su motocicleta.
Si tiene cualquier otra consulta o pregunta, no dude en ponerse en contacto con nosotros.
Atentamente,
Juan Gallardo
_________________
Atención al Cliente
Honda Motor Europe Ltd. Sucursal en España
Tel. 902 42 46 46 / 902 02 61 00
www.honda.es
asi que "por el momento" calma tensa... >:( >:(
isislot
Esto de las campañas, a mi, me toca la fibra sensible, por no decir otras partes. Resulta que despues de cuatro años de comprar un Passat, me viene una carta, para que me pase por el concesionario, que mi coche esta afectado por un mal funcionamiento en el sistema de inyeccion y que sin conste por mi parte, me cambiaran los cuatro inyectores :icon_eek: :icon_eek: :icon_eek:. Digo pues Olé, voy me los cambian ( yo no note nada, ni antes ni despues del cambio). Pero resulta que despues del cambio y curiosamente enpieza a funcionar mal, una de las bombas del gasoil, la que empuja el susodicho desde el deposito a la que empuja este hasta los inyectores, total que toda mi alegria, se conviete en tristeza, la p...........ta bomba con el aforador y toda la parafernalia, me salio por unos 1.000€ y pico, y hasta el dia de hoy con 8 años que hace que lo tengo, no he llegado a saber, que hubiera pasado si hubiese ignorado la dichosa campaña. Un saludo y birras pa to Dios.
