Inyeccion y PGM??
Iniciado por Vicente, Septiembre 17, 2010, 12:14:59 PM
Vicente
Hola de nuevo.
Alguien sabria decirme lo que significan las siglas PGM-FI
Las he visto en una CBR600 y no se porque , me da que la VFR tambien las lleva.
Al meter la llave y hacer contacto, en el cuadro de mandos, se enciende una luz(FI)
Fuel Injection, pero lo de PGM, me intriga.
[/URL]  Uploaded with ImageShack.us[/img]
Cita de: VicenteHola de nuevo.
ProGraMmed Fuel Injection  :wink:
v'sssssssssssss
O en cristiano: Inyección de gasofa programada
Programmed fuel injection
From Wikipedia, the free encyclopedia
Programmed Fuel Injection, or PGMFI/PGM-FI, is an electronic fuel injection system initially developed by Honda more than 20 years ago. This system has been applied to Honda motorcycles, Formula One racing cars, and automobiles.
History
Since the advent of electronic fuel injection (EFI), Honda has used this method to their full advantage. Honda offered some of the first low priced vehicles in North America to employ programmed fuel injection. Originally developed for racing cars, PGM-FI made its way into Honda automobiles in the late 1980s in their Accord and Prelude models which featured the Honda A20A, A20A3 & A20A4 engines (Honda A engine). The 1986 Honda Civics were the first Civics to feature PGM-FI. In 1998, Honda built the first motorcycle with PGM-FI, the VFR800FI. Honda had this system copyrighted from 1987-1997.
Operation
PGM-FI works by injecting the right amount of fuel per cylinder based on specific engine data. The Engine Control Unit (ECU) has sensors which measure the temperatures of the engine, coolant, oil, and outside air as well as pressure sensors to monitor oil and barometric pressure. Based on these readings and the location of the throttle, the ECU calculates how much oxygen and fuel should be mixed for optimal and efficient performance.
Cars with PGM-FI do not have to sit and warm the engine up in the winter season because the ECU calculates at what RPM and the fuel and air mixture the car requires to be at a normal engine temperature range.
Vicente
This one quite clear, thank you for the explanation and you I owe a few cervezas.(beers)
Health and regards.
Esta todo claro, gracias por la explicacion y os debo unas cervezas.(cervezas)
Salud y saludos
