Honda SCS
Iniciado por straits, Septiembre 24, 2024, 05:19:30 PM
straits
Honda SCS o "Honda service Short service connector.
En resumen, el chequeo o diagnostico rapido de honda mediante codigos de intermitencia
Gracias a MCU innovations, Tengo alguna idea algo mas ancha del tema errores DTC de Honda.
ManufacturerTypeCodeDescription
HondaPGM-FI001-1MAP sensor circuit low voltage
HondaPGM-FI001-2MAP sensor circuit high voltage
HondaPGM-FI002-1MAP sensor performance problem
HondaPGM-FI006-1Barometric sensor circuit low voltage
HondaPGM-FI006-2Barometric sensor circuit high voltage
HondaPGM-FI007-1ECT sensor circuit low voltage
HondaPGM-FI007-2ECT sensor circuit high voltage
HondaPGM-FI008-1TP sensor circuit low voltage
HondaPGM-FI008-2TP sensor circuit high voltage
HondaPGM-FI009-1IAT sensor circuit low voltage
HondaPGM-FI009-2IAT sensor circuit high voltage
HondaPGM-FI011-1VS sensor no signal
HondaPGM-FI012-1No.1 primary injector circuit malfunction
HondaPGM-FI013-1No.2 primary injector circuit malfunction
HondaPGM-FI014-1No.3 primary injector circuit malfunction
HondaPGM-FI015-1No.4 primary injector circuit malfunction
HondaPGM-FI016-1No.1 secondary injector circuit malfunction
HondaPGM-FI017-1No.2 secondary injector circuit malfunction
HondaPGM-FI018-1CMP sensor no signal
HondaPGM-FI019-1CKP sensor no signal
HondaPGM-FI021-10₂ sensor bank 1 low voltage
HondaPGM-FI021-20₂ sensor bank 1 high voltage
HondaPGM-FI022-10₂ sensor bank 1 low voltage
HondaPGM-FI022-20₂ sensor bank 2 high voltage
HondaPGM-FI023-10₂ sensor bank 1 heater malfunction
HondaPGM-FI024-10₂ sensor bank 2 heater malfunction
HondaPGM-FI025-2Knock sensor circuit malfunction
HondaPGM-FI025-3Knock sensor circuit malfunction
HondaPGM-FI029-1IACV circuit malfunction
HondaPGM-FI033-2ECM EEPROM malfunction
HondaPGM-FI034-1ECV POT low voltage malfunction
HondaPGM-FI034-2ECV POT high voltage malfunction
HondaPGM-FI035-1EGCA malfunction
HondaPGM-FI036-1A/F sensor malfunction
HondaPGM-FI038-1A/F sensor heater malfunction
HondaPGM-FI041-1Shiftdrum angle sensor circuit low voltage
HondaPGM-FI041-2Shiftdrum angle sensor circuit high voltage
HondaPGM-FI048-1No.3 secondary injector circuit malfunction
HondaPGM-FI049-1No.4 secondary injector circuit malfunction
HondaPGM-FI051-1HESD linear solenoid malfunction
HondaPGM-FI054-1Bank angle sensor circuit low voltage
HondaPGM-FI054-2Bank angle sensor circuit high voltage
HondaPGM-FI056-1Knock sensor IC malfunction
HondaPGM-FI066-1Rear wheel speed sensor no signal
HondaPGM-FI067-1Front wheel speed sensor no signal
HondaPGM-FI071-1TP sensor 1 low voltage
HondaPGM-FI071-2TP sensor 1 high voltage
HondaPGM-FI072-1TP sensor 2 low voltage
HondaPGM-FI072-2TP sensor 2 high voltage
HondaPGM-FI073-1TP sensors 1 and 2 voltage correlation malfunction
HondaPGM-FI073-2TP sensors 1 and 2 short circuit
HondaPGM-FI074-1APS 1 (TCP) low voltage
HondaPGM-FI074-2APS 1 (TCP) high voltage
HondaPGM-FI075-1APS 2 (TCP) low voltage
HondaPGM-FI075-2APS 2 (TCP) high voltage
HondaPGM-FI076-1APS 1 - 2 (TCP) voltage correlation malfunction
HondaPGM-FI077-1TBW return spring malfunction
HondaPGM-FI078-1TBW motor malfunction
HondaPGM-FI079-1TBW system control correlation malfunction
HondaPGM-FI082-1Fast idle solenoid valve malfunction
HondaPGM-FI084-1CPU in the ECM malfunction
HondaPGM-FI085-1TBW relay failure (ON side)
HondaPGM-FI085-2TBW relay failure (OFF side)
HondaPGM-FI086-1Serial communication malfunction
HondaPGM-FI088-1EVAP purge control solenoid valve malfunction
HondaPGM-FI089-1PAIR control solenoid valve malfunction
HondaPGM-FI091-1No. 1 ignition coil circuit malfunction
HondaPGM-FI092-2No. 2 ignition coil circuit malfunction
HondaPGM-FI093-1No. 3 ignition coil circuit malfunction
HondaPGM-FI094-1No. 4 ignition coil circuit malfunction
HondaPGM-FI099-1IMU circuit malfunction
HondaPGM-FI103-1CAN communication malfunction
HondaPGM-FI103-2CAN communication malfunction
HondaPGM-FI103-3CAN communication malfunction
HondaPGM-FI103-4CAN communication malfunction
HondaPGM-FI107-1Shift stroke sensor circuit low voltage
HondaPGM-FI107-2Shift stroke sensor circuit high voltage
HondaPGM-FI108-1Shift spindle switch circuit low voltage
HondaPGM-FI108-2Shift spindle switch circuit high voltage
HondaPGM-FI113-1Clutch switch circuit low voltage
:risa7: e=mc^2
